Additional water temp sensor. Where? Saph
Old Mar 21, 2016 | 07:16 AM
jdsjojo's Avatar
jdsjojo
Default Additional water temp sensor. Where? Saph
Following a recent trackday I found the original ford one can give you a false reading as I lost coolant from the top rad hose after pre tightening jubilees before venturing out on track (must have just overtightened it). After pitting, sorting the leak and topping up coolant I went back out and had no probs.
I came back in and the car took 30 mins to cool down and for the fans to stop running. I then realised that I never bled the system (didn't think I'd lost much water) turns out I lost about 2 litres.
So I want to fit another temp gauge to give me the heads up that something isn't correct.
Where's the best place to retro fit an additional water temp sensor?
Old Mar 21, 2016 | 09:49 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
I have a boss welded on the thermostat housing with a capillary gauge in the dash
Old Mar 21, 2016 | 10:24 AM
cozzy jeff's Avatar
cozzy jeff
I drilled and tapped the thermostat housing
900ss
18
Jan 29, 2017 07:43 PM
benw456
Mar 8, 2016 08:32 AM
cossie330
Mar 8, 2016 07:51 AM
bassboy
Feb 26, 2016 03:09 PM
