Window rubber question
The glass is bonded, but the rubber trims are not. However, to get them sitting right, you need to fit them to the glass first, then fit the glass and trim at the same time. You won't get them back in with the glass already glued in.
Farooq
Mar 17, 2016 09:29 PM
