ST170 Gear Problems
Old Mar 18, 2016 | 06:12 PM
Nizzy's Avatar
Nizzy
Unhappy ST170 Gear Problems
Hi, I have purchased a 2002 Ford Focus ST170 as a project car, but I am having some problems. I can't put the car into reverse and in order to drive off I need to start in second. Also, the gear stick is very ermm.. flimsy could be the word. If i moved the gear stick to the left, just below gear 1, it will stay there if i don't move it. Please help me as I am trying to get the car back on the road ASAP. What could the possible problems be?
Thank You
Niz
Old Mar 18, 2016 | 07:24 PM
STeve's Avatar
Super Moderator
common for the gear cables to stretch also common for gear selector to be wear causing floppyness
Old Mar 19, 2016 | 01:01 PM
Nizzy's Avatar
Nizzy
Thank you, but how much do you think I will need to spend to fix this problem?
Old Mar 19, 2016 | 02:02 PM
STeve's Avatar
Super Moderator
I would get it diagnosed fully first before spending any money, I break st170s and can supply you parts but you need a professional to look to be sure
Old Mar 21, 2016 | 04:59 PM
The ST17O i have at the moment was the same when my mate had it. It took me 20 mins to adjust the cables and road test it.
Remove the air box and you will see the adjustment clips on the cables. Pull it out get someone to hold your gear stick in the middle and push the clip back in.
davidglanza
Feb 24, 2016 12:17 PM
Kiezlucas
Ford Focus ST
27
Feb 23, 2016 09:25 AM
JamboRS
Ford Focus RS Parts for Sale.
Feb 21, 2016 02:57 PM
salsheikh
Alloy wheels and ICE for sale
Feb 19, 2016 11:01 AM
JoshXR2
Feb 17, 2016 05:53 PM
