Full geometry settings needed.
Wye Valley Hardcore
What's are people's tried and tested 4 wheel alignment settings?
Camber, caster and toe for front and rear.
These settings seem to be kicking about, but has anyone got and experience with them?
1.5 degrees negative camber.
0 degrees 30 minutes toe IN.
That is the Grp A RS Turbo (Series 1) settings which will make it more controlable on a straights but the turn in won't be as easy or wanting.
If you want to try these settings for a tight turn / track, set the toe to this..
0 degrees 30 minutes toe OUT.
That will make it more nervous in a straight but down the lanes, it will turn in really sharp.
In case you are having a 4 wheel alignment here are the other recommeded settings..
2 1/2 degrees positive castor.
Rear.
0 degrees 30 minutes toe in.
1 1/2 to 2 degrees negative camber
Rear.
im running 2.5 degrees camber front
1-1.5ish rear
castor is 4 degrees but you wont get that
mine is set very slightly toe out on the front and very slight toe in on the rear
you also have corner weight balancing
1-1.5ish rear
Russ Payne
18
May 6, 2017 02:09 PM
SmudgerByName
Mar 13, 2016 04:30 PM
