Holley HP-125 Low Pressure / High Flow - Ultimate Fuel System Lift Pump
On the bay...
http://www.ebay.co.uk/itm/Holley-HP1...-/191826053418
I chose this for a 800-1000bhp Cosworth YB fuel system lift pump.
If you're running twin Bosch 044's flat out, this pump WILL flow enough fuel out your tank and into the swirl pot to keep up
Russ Payne
Mar 9, 2016 07:12 AM
