Does anyone have or do a wiring diagram for
Old Apr 7, 2005 | 10:30 AM
Alps Pacino's Avatar
Alps Pacino
Default Does anyone have or do a wiring diagram for
Fitting Cossie managment on a series1. Cant see it being that hard to do if someone has a wiring diagram.
Old Apr 7, 2005 | 10:37 AM
Ryan's Avatar
Ryan
A Cossy ECU & loom only require 3 wire to run:
Permanant Live
Ignition Live
Pump Trigger
The car will run with just those connected.
Feeds off the cossy loom which need to be wired into a s1 loom are:
Rev Counter = Green
Water Temp Sensor = Brown\White
Old Apr 7, 2005 | 01:43 PM
Alps Pacino
Rev Counter = Green
_________________
You mean the green wire and the brown/white is on the cossie loom or the other way round. Which wires do these need connecting to ie green-?
Old Apr 7, 2005 | 01:52 PM
jon@work's Avatar
jon@work
the green on the cossie loom needs to be connected to the wire that feeds your rev counter - check for continuity between one of your original ignition coil wires and the multiplug on the back of your clocks to identify the right wire.
do similarly for the brown/white on the cossie loom that connects into the back of your clocks to feed the temp gauge.
Old Apr 7, 2005 | 01:56 PM
Alps Pacino
Souds pretty easy i think i have a manual with all the wiring diagrams for a s1 somewhere. Sounds a LOT easier than i first thought.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
THE RADMAN
Sep 19, 2015 12:57 PM
