Group-A dump valve
I got hold of a second hand spec-r dump valve recently and have just tried it on my sapphire.
The car is fitted with a twin piston motorsport developements one at the mo but thought I'd try a diaphragm one to see if I prefered the noise.
When the spec-r one is fitted and the car is idling the dump valve leaks a tiny bit of air...
The diaphragm isn't split so I was thinking maybe the spring in it is not heavy duty enough??
Anyone running one of these?
Cheers Paul
Cheers Paul
I don't have a vaccine gauge fitted.
The leaking air is from the boost hose side not the vacuum side.
Idles fine, I think I just need to take it on th road and try it out....
Cheers Paul
Cheers Paul
lockie
Mar 7, 2016 05:02 PM
3doorcozmess
Mar 7, 2016 01:44 PM
