Main bearings rear oversized
Old Mar 1, 2016 | 02:17 PM
Ridgey's Avatar
Ridgey
Default Main bearings rear oversized
Does anyone know of a supplier that can supply over sized REAR main bearings. ??
What this means is the block has had the mains line bored larger.
thanks
Old Mar 1, 2016 | 06:11 PM
Adam-M's Avatar
Adam-M
Strange I thought they cut and shut the caps then line bore them to the original size?
Old Mar 2, 2016 | 08:32 AM
mk1yb's Avatar
mk1yb
AE used to sell oversize main bearings when I dealt with them years ago. Don't know if they still do them, but yes, you are correct when you say the block and caps are line bored which required an oversize bearing.
Tinshaw
Feb 29, 2016 09:04 PM
Dan_RS500
Feb 28, 2016 07:07 PM
RSmark84
Feb 28, 2016 04:33 PM
Caddyshack
Feb 26, 2016 06:35 PM
3doorcozmess
27
Feb 9, 2016 11:51 AM
