Fiesta RS turbo Rear anti roll bar removal.
The 4 bushes are perished so i'm fitting replacements. Ive managed to remove the front clamps and drop the roll bar down.... But the rear 2 clamps share the same (pinch) bolts as the rear struts. If i wack these out will the holes still be aligned for me to put the bolts back in once the roll bar is fully removed?
The car's rear end has been driven up on ramps. So the wheels are technically on the ground still.
