heated screen info mk1.5 focus
had a small chip on the screen the other day , a few mm accross...now that whole side of the screen doesnt heat
does one chip really stop the whole side working ? or might it have done a fuse ??
any help...was loving the heated screen too
Take the scuttle panel off (don't break the clips) and check the wiring connections on the passenger side. Not uncommon for them to corrode and come off. Could be a coincidence as if shouldn't stop the whole element working.
Highly unlikely that a stone chip a few mm across will stop a screen heating element from working. They're a lot tougher than light bulb elements and encased in the laminate, not free hanging. It's more likely to be a coincidence as Richie says, and either be a fuse or relay, or the connection.
bassboy
Feb 26, 2016 03:09 PM
