2wd cozzy rear parts
From another website, not sure how accurate but no harm for info.
Rear
1. Disc
2WD 5022667
4WD 5024175
3. Sheild
2WD 1640079
4wd 1661472
5. Bearing Carrier 1637603
6. Bearing 6140418
7. Seal 6140417
8. Hub 6156880
9. Stud 6586309
10. Washer 6102937
11. Nut Hex M22x1.5mm
Right Hand Thread 6133688
Left Hand Thread 6133689
Rear 2
2. Caliper
2WD
RH 6152222
LH 6152224
4WD
RH 6180198
LH 6180199
4. Bleed Screw 1486865
13. Bolt Hex M10x25mm 1619124
15. Pads
2WD 1637872
4WD 1652206
18. Caliper Repair Kit 6141146
19. Parking Brake Spring Repair
RH 6141147
LH 6141148
20. Parking Brake Complete Repair Kit 6127710
21. Parking Brake Lever Repair Kit
RH 1651087
LH 1651088
22. Pad Mounting Parts 6137297
24. Anti Rattle Plate 1661636
Rear
1. Disc
2WD 5022667
4WD 5024175
3. Sheild
2WD 1640079
4wd 1661472
6. Bearing 6140418
7. Seal 6140417
8. Hub 6156880
9. Stud 6586309
10. Washer 6102937
Rear 2
2. Caliper
2WD
RH 6152222
LH 6152224
4WD
RH 6180198
LH 6180199
15. Pads
2WD 1637872
4WD 1652206
RH 6141147
LH 6141148
RH 1651087
LH 1651088
