forged Piston suggestons for zetec turbo build!
Old Feb 17, 2016 | 09:26 PM
Robliddle's Avatar
Robliddle
Default forged Piston suggestons for zetec turbo build!
After much thought regarding my turbo zetec build, ive decided to do it right with a fresh engine build instead of the st170 route or the decompression plate method.
Ive got a 20ltr black top motor which will get a tear down at the weekend.
Just wondered what forged pistons are being used, is there a popular brand or type typical to this conversion, and whats the ideal compression ratio to aim for.
Any advise from you guys that run these motors would be much appreciated.
Old Feb 18, 2016 | 10:01 AM
zetaboostboy522bhp's Avatar
zetaboostboy522bhp
Contact ian howell/area six he has custom cp / arais piston made to his spec and they are not much more than a cheap set of off the shelf piston. Ian is a very helpful guy aswell . The comp ratio he likes to use is 7:45:1
Cheers paul
Old Feb 18, 2016 | 12:01 PM
saph in dorset's Avatar
saph in dorset
you can get wossner pistons in varying compression ratios.
I will be going this route with mine along with pec rods.
comes in at around Ł800 for the full set of both.
Old Feb 18, 2016 | 06:46 PM
nevsrevs's Avatar
nevsrevs
Can't go wrong with talking to Ian Howell as above, what he says is all ways truthful and like said, he will help out along the build
Old Feb 18, 2016 | 08:25 PM
Robliddle's Avatar
Robliddle
Does he have a website, does he still trade as area six ??
Old Feb 18, 2016 | 08:43 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Use focus RS pistons if you want to make it a little cheaper. Ford/mahle probably spent thousands working out what was the best for that engine, so makes sense to use them
Old Feb 19, 2016 | 09:42 AM
RUBY123's Avatar
RUBY123
I have some brand new area six pistons
Old Feb 19, 2016 | 07:51 PM
zetaboostboy522bhp
You can contact him on Facebook, plus Ian's piston have the oil ring machined lower on the piston to help blow by. Certain Pistons makes I wouldn't use but cp and arias are 2 of the best in the world just check there webpage out
Old Feb 19, 2016 | 10:04 PM
Turbo Zetec
Engine Machinist
i would rate CP, but i've had some custom arias pistons before that were machined like crap. I know they're supposed to be good, but i wasn't impressed at all.
Old Feb 19, 2016 | 11:18 PM
zetaboostboy522bhp
Mine were super quality but I think ian use mainly cp because they have faster turn around
Cheers paul
Old Feb 20, 2016 | 06:46 AM
nevsrevs's Avatar
nevsrevs
The last set I bought off Ian where cosworth green skirts, and he rated them well as a slighty cheaper option to cp's but I'm not sure you can still get them
Old Feb 20, 2016 | 06:09 PM
slammedorion's Avatar
slammedorion
Try contacting Jano @ Oddkidcreation
Old Feb 20, 2016 | 08:38 PM
luke89's Avatar
luke89
Team HOTHOT!
I have cosworth green skirts apparently from Ian as well
Old Feb 21, 2016 | 03:24 PM
zetaboostboy522bhp
I know Ian's brother in law or cousin worked / works for cosworth , years ago he couldn't get them made as a single set it was always large batch orders so maybe they have changed the policy and are happy to machine a set of Pistons . I can remember him telling me he paid a few grand for a lorry load of wrc focus zetec engine parts , he had around 20 cgi blocks and was selling them for a Ł100 each lol
Old Feb 21, 2016 | 04:20 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
i used wiseco in my build a few years back, but if you add in customs charges etc i only saved a couple of hundred quid over buying from the uk.
i did have the ratio at 8.0:1 and had the oil ring moved down a little as i knew ian had this done too with the cp's.
it was a pain to get them organised though, loads of emails as they only listed high compression ones, no issues with the product though, very little rattle when cold if any and no oil usage in the time i used them.
Sakis Gogos
Feb 12, 2016 08:22 AM
Bigdaggy123
Ford Focus (All Models)
Feb 1, 2016 03:41 PM
Tigercatkid
Ford Focus ST
Jan 23, 2016 03:27 PM
t5syy
Ford Focus Range
Jan 23, 2016 10:07 AM
