fuel rail
Ford make a special tool to remove it but I think you can also use an air con tool - http://www.ebay.com.au/itm/VS0454-SE...ed6&rmvSB=true
Have used a 15mm olive from a compression fitting before, just split it wrap it round the tube and slide it into the spring to release the fitting, have also used a short piece of plastic pipe of similar diameter, split it and chamfer the edge push it over the pipe and push towards the spring to release, if all that makes sense!!
dickdastardley
Feb 15, 2016 11:27 AM
Romain 83
Feb 10, 2016 09:26 AM
