ABS Pump
Old Feb 7, 2016 | 07:29 PM
Dearo's Avatar
Dearo
Default ABS Pump
Hi All,
Can you fit a 4 x 4 pump on a 3 door Cossie?
I've been offered an Escort Cosworth pump as mine is kaput !!
Old Feb 7, 2016 | 09:02 PM
doga-ot's Avatar
doga-ot
Yes 4x4 pump sits little bit more to the left (towards wing) giving slightly more room near turbo
Old Feb 7, 2016 | 09:37 PM
Dearo's Avatar
Dearo
Will my current ABS loom and bulkhead brake pipes fit ?
Old Feb 8, 2016 | 06:24 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Wiring wise it will fit but the pipes will be different so you'll either need the pipes from a 4x4 or you'll have to make new ones.
The 4x4 pump motor also sits closer towards the exhaust manifold. I have an extension piece between the 2 sections on my 2wd manifold due to running a GT30 so this brought the manifold VERY close to the motor so changed my 4x4 pump to a 2wd one. You should be fine if using a normal 2wd manifold with no extension piece.
london_chris
25
Apr 3, 2024 09:40 PM
Romain 83
13
Feb 9, 2016 06:53 PM
PETESTURBO
Alloy wheels and ICE for sale
Feb 1, 2016 11:23 PM
jacobwigley
Jan 31, 2016 07:12 PM
evoboy
Jan 19, 2016 07:48 PM
