Engine conversion over fueling won't run properly
Old Feb 6, 2016 | 08:15 PM
Tommy777's Avatar
Tommy777
Default Engine conversion over fueling won't run properly
Hi can any one help I have done a black to conversion with the efi convertion plate,2.0 biege injectors and throttle body.i have changed cam
Sensors maf,idle speed control ,coil pack,plugs,leads,pressure reg,gaskets,throttle body's,it has the 2.0 ecu and key reader,I've resolves all wiering,and checked all air feeds ect. It jus keeps over fueling and won't Rev right.. It's will drive sum times then it won't back fires,black plugs any help would be appreciated.it had the silver top in but engine gave up.mk5 escort
Old Feb 10, 2016 | 08:37 PM
Tommy777's Avatar
Tommy777
[QUOTE=3doorcozmess;6656064]Pectel T6 ECU is used on alot on old school rally cars I would say have gibbs would be your best bet.
Si[/QUOTE
Can I not just replace ecu and key reader. Instead of having it re programmed..thanks for the reply new to site don't quite no how to use it.
Old Feb 10, 2016 | 09:46 PM
3doorcozmess's Avatar
3doorcozmess
[QUOTE=Tommy777;6656108]
Si[/QUOTE
Message deleted sorry posted in wrong thread
John 2.9
Nov 16, 2016 06:18 PM
CoreyCosworth
59
Jan 15, 2016 10:23 AM
SmudgerByName
Jan 13, 2016 12:29 PM
Antony Mann
Escort MK 5 / MK 6
Jan 7, 2016 10:33 PM
davidfordrs
Jan 7, 2016 08:43 PM
