Fuel pump removal MK3 1.8
Old Feb 6, 2016 | 11:23 AM
No-nonsensical's Avatar
No-nonsensical
Default Fuel pump removal MK3 1.8
Hi all I've just acquired a 2001 Y plate Mondy petrol as a runaround from a guy from down the road, with an issue that I'm pretty sure I've found.
I have spark, I've checked fuse and relay for the pump and all ok. There is no noise from the pump when the ignition is on. I have power to the pump. It's seems there no fuel getting to the injectors.
My question is this. As you prob know the appature under the seat is offset to the pump on top of the tank. Haynes says remove the tank, but CAN it be removed in situ without cutting and making the hole bigger?
Thanks
Old Feb 7, 2016 | 05:15 AM
mk3ste's Avatar
mk3ste
Yes you can remove from under the seat
Old Feb 7, 2016 | 07:21 AM
No-nonsensical
Can you elaborate? Will the ring and the top of the sender pull through the hole, being offset
Old Feb 8, 2016 | 05:17 PM
No-nonsensical
Just to wrap this up....all done a running like a champ. Thing is, why the hell didn't ford just make the hole larger? In the i levered the hole outwards so the lip of the hole was vertical. It was still a tight squeeze to get the lock ring out and but better than fannying around with dropping the tank. So for those that may stumble across this thread it is doable. You'll have an ugly looking hole but who cares when the seats cover it!
Doodah
Feb 11, 2016 05:38 PM
jason3249
Feb 10, 2016 02:47 PM
RSCossieGaz
Feb 5, 2016 02:18 PM
everway9
Ford Fiesta
Feb 5, 2016 12:16 PM
GrahamMV
Ford KUGA
Jan 31, 2016 01:09 PM
