stg3 t3, gt28, t34 etc. turbo spec help
Old Feb 5, 2016 | 11:11 AM
griffo69's Avatar
griffo69
Default stg3 t3, gt28, t34 etc. turbo spec help
Hi guys. I need help with which turbo spec to run on my new engine if anyone can help?
Not after a lag monster if possible.
Car is a s2 turbo
Engine spec is
Full p8 cosworth management, coilpack etc
Siemens injectors
Cvh
Worked head
Kent 35 cam kit
Double valve springs
Kent pulley
Block slightly overbored
5 layer steel head gasket
Wossner 8:1 forged pistons
Pec steel rods
New genuine Ford oil pump
New water pump
Unground crank
New sump
Arp bolts
Arp stud and nut kit
Old Feb 6, 2016 | 01:41 PM
griffo69's Avatar
griffo69
Anyone ???
Old Feb 6, 2016 | 04:13 PM
Chas's Avatar
Chas
Originally Posted by griffo69
Anyone ???
What kind of power are you hoping for and what kind of characteristics?
I am tempted to suggest a Stage 3 T3 but the lag will go up.
I am running a Stage 2(ish) on mine (a 1.8 ZVH running MFI, Kent cam, Stage 3 head, ARP bolts at 18PSI with it making 225BHP. I reckon there is more to come if I can get it onto EFI and dabble with the cam timing. I also reckon it runs out of puff higher up in the rev range, partially down to it being a ZVH. I do sometimes wonder about putting on a Stage 3 (basically it has a larger exhaust housing and turbine), but this car is currently a little laggy to what I am used to with turbo cars (a chipped and mildly tuned 944 Turbo and a stock Mondeo 2.5T) but not horrific. That and the torque curve is very flat:
Old Feb 6, 2016 | 11:17 PM
Nosmonkey's Avatar
Nosmonkey
Should stick my spare stage 2 on Dai and see how it goes, if it's not enough then get a stage 3 and embrace the lag!
Old Feb 8, 2016 | 03:11 PM
stuart collins's Avatar
stuart collins
ring owens and ask them , i would thin sumthin like a gtx25 or gtx28
Old Feb 10, 2016 | 02:38 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
Target BHP and budget are what we need to know to advise you mate, but as Stu has suggested one of the GTX or GT range will spool nicely compared to an old T series and flow for good power too.
Old Feb 10, 2016 | 03:50 PM
griffo69's Avatar
griffo69
Cheers for the info lads
Target power would be hopefully around 300 or in the very late 200s . I'm ideally after one that isn't a lag monster, something nice and responsive . Would you know if these turbos fit the original cvh lay out , I mean pipework etc
Old Feb 10, 2016 | 03:52 PM
griffo69's Avatar
griffo69
Cheers for the offer mate
Old Feb 16, 2016 | 11:07 AM
griffo69's Avatar
griffo69
Bttt Lads
Old Feb 16, 2016 | 11:46 AM
TIL13R's Avatar
TIL13R
I have a very similar setup on my Fiesta Turbo... I run a Turbo Technics T3 stg 3 and TBH I don't find it that 'laggy' at all...
Regards
Richard
Old Feb 16, 2016 | 12:31 PM
Rob_DOHC's Avatar
Rob_DOHC
That is a very flat torque curve for a cvh/zvh! Normally they drop off past 5000 rpm quite badly unless you have a cam/good headwork/more boost.
You are quite rich past 5K though. You would possibly pick up a little power if you were not so rich.
To the OP, what power do you want? Stage 2/3 T3 is relatively cheap and very easy to install. If budget is less of a concern then I would be looking at the GT or GTX range as mentioned.
Old Feb 16, 2016 | 09:24 PM
Nosmonkey's Avatar
Nosmonkey
I think if you're going for a new turbo going for a roller bearing unit is logical especially if you want to cut down on lag. Something like a GT2560R would be good or perhaps a GTX3067R as they're a T3 flange.
Old Feb 17, 2016 | 04:53 PM
Rob_DOHC's Avatar
Rob_DOHC
GT2560R's are not ideal for high boost rs turbo's. Have a look at the pressure map. They are well suited to higher capacity lower boost applications.
Old Feb 17, 2016 | 08:52 PM
Chas's Avatar
Chas
Many thanks!
The richness I am aware of, although it does begin to lean off after 6kRPM;a certain Derby based outfit reckon the injection system is dealing with more than it can handle, even with the 5th injector. It's one reason why I am considering going to a modern EFI setup, maybe one of yours .
It's good to see the GTX ranges being mentioned, it will be something to potentially look into in the future
Old Feb 21, 2016 | 04:38 PM
griffo69's Avatar
griffo69
Around the late 200s - 300 ish if possible mate. What mods would be needed to run a gt or gtx series turbo ? Also what sort of price are these ?
Old Feb 28, 2016 | 07:01 PM
griffo69's Avatar
griffo69
Still need help please guys.
Old Mar 4, 2016 | 10:48 PM
Piston Broke's Avatar
Piston Broke
In run a stage 3. I got Dan at turbo rebuild blackpool to do me a custom built turbo Griffo and to be fair am very happy and no lag to bother me to be honest. Not just about the power the engine has now but also a stage 3 will cover a future when it comes to wanting more power if you do as you say dude 😆
Old Mar 10, 2016 | 04:12 PM
Marc D's Avatar
Marc D
Id just go with a stage 3 t3
Old Mar 12, 2016 | 01:26 PM
griffo69's Avatar
griffo69
What power are the stage 3 turbos good for lads ???? Much lag with the .48 exhaust housing ???
Old Mar 12, 2016 | 07:08 PM
russ rs's Avatar
russ rs
Kick in around 3200rpm and have seen 300bhp on them
Old Mar 12, 2016 | 07:26 PM
griffo69's Avatar
griffo69
Is this with the cossie . 48 housing or the erst .48 housing ??? Seen that Burton's sell the erst stage 3
Old Mar 12, 2016 | 07:28 PM
russ rs's Avatar
russ rs
Escort don't use button Cr turbos or wilkey off here
Old Mar 12, 2016 | 07:32 PM
griffo69's Avatar
griffo69
Cheers again mate. I'll drop him a message
Old Mar 20, 2016 | 04:03 PM
griffo69's Avatar
griffo69
Bttt Lads
Old Mar 28, 2016 | 05:42 PM
griffo69's Avatar
griffo69
Bttt lads. Would prefer a more responsive turbo with a little less power over a big lag turbo if possible
davidfordrs
Jan 7, 2016 08:43 PM
ads rst
Jan 7, 2016 03:36 PM
anthony lea
Jan 7, 2016 09:59 AM
oilman
Trader Parts for Sale.
Jan 6, 2016 01:12 PM
