Parts required to finish off my sapphire resto
Hi all.
Looking for a few random bits to finish off my saph cos resto.
Prefer to buy from a member and not a breaker if possible.
I need
The clutch lever cover which covers the opening in the bell housing and the lever.
2 seat belt bolts for the rear belts.
A t5 gearbox tail shaft oil seal
1 offside plastic front bumper bracket,must be mint with nut and round peg still attached.
Alloy sideskirt clips,new or vgc please.
Rear caliper spring plates/shields.these cover the opening in the rear caliper above the brake pads.
A new/used but mint cosworth water bottle,bought a new 1 but the neck is wrong so has to come from a cosworth.
P.m me w.h.y
Thanks,lee
I need
P.m me w.h.y
Thanks,lee
Gearbox seal your get from any bearing specialist if you have the inside and outside diameter for a few quid. I'm 99% sure I have the bell housing cover and I'll not be using it as I'm going centre push. I'll have a look at the weekend as I need to nip down there to get my old oil pump
Great,got a few bits on eBay just now.
No longer needing
Gearbox seal
Fuel line clips
There's a cover on eBay,I bought bits from the guy before so I have messaged him to see what like it is and if he has anything else.
I'll ipdate this thread if I get 1,if not I'll hear from you at the weekend.
Ta,lee
No longer needing
Gearbox seal
Fuel line clips
Ta,lee
Bailes1992
47
Jan 19, 2016 02:19 PM
Blackxr4x4
Jan 10, 2016 10:29 PM
