AP 6 pots on a sapph, wheels?
Mostly road but Nurburgring every year, I'd prefer 17" but for now my build costs are high so just trying to find a suitable 18" wheel, I'm pretty sure the focus wheel fits over these brakes on a focus but on sapph not sure, plus arches will need to be rolled for that wheel.
I've researched this a lot over the last 6 month and spoken to a good few owners and I can confirm,
8x18 ET35 comp mo6 (new or old style) will fit over AP 6pots (7040/9040 caliper) and 362x32 discs on 4wd
You can fit 362's under certain 17 inch rims if your 2wd as the disc sits further into the inner rim
If it's 2wd you can go to 378's if you shave some off the caliper
I want the MO6s too, not sure what offset but reading here ET35 I guess. Could do the 362mm discs if they're a better fit. Cheers lads.
Philip.
Ok so it's on my mondeo, but you can see the size of the disc compared to the wheel and how much space there is for the calliper
That's 362's and the wheel was made with an et40
On a saph!
Escos can go to 378's as the offset is down ET15.
The problem with the saph 4wd is the caliper runs so close to the spokes on the wheel, I have no info on the CP5555 calipers
zetecbeast
Ford Focus RS Parts for Sale.
Jul 5, 2016 11:22 PM
rb5286
May 9, 2016 07:41 AM
original
Feb 4, 2016 04:00 PM
rb5286
Feb 2, 2016 11:38 PM
griffo69
Jan 31, 2016 07:57 PM
