4x4 cosworth engine
I have a complete 4x4 saff engine and box and loom and wish to fit the engine in A mk6 petrol transit
What needs changing to run it rwd
Is it just the sump or is the clutch and flywheel different
Is the wiring harness the same as a 2wd and can be cut and wired up with the 5 wires ?
yes you can use the 4wd clutch and flywheel
wiring is the same depending which ecu and tps you are using
steve
steve
I take you have a Cossie YB engine.
You'll need a T5 gearbox to take the abuse as it were. I think the clutch fork bearing is different but clutch flywheel and pressure plate can be left.
Yeah 2wd sump and oil pick to change.
Loom wise stick with a 4x4 loom. Have you got the right ecu (L8)?? Plus a Bosch 044 fuel pump minimum.
A Cossie rear diff depending on what power you will run.
