Efi turbo problems
Old Jan 30, 2016 | 01:39 PM
Gem frst's Avatar
Gem frst
Default Efi turbo problems
Having trouble with my xr2i converted fiesta rs turbo runs rough on idle and when you rev it it won't settle just cuts out its running an ofab ecu with t3 any ideas would help
Old Jan 30, 2016 | 05:23 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Have u checked all pipes/hoses could be a air leak if there not on tight...if u done a conversion it will need a set up at a tuners to set up fueling/timing/revs/boost ect
Old Jan 30, 2016 | 08:46 PM
mentalasanything's Avatar
mentalasanything
What injectors and chip are you running?
Lee
Old Jan 30, 2016 | 10:09 PM
cge's Avatar
cge
Rs turbo loom or converted xr2i loom?
chris
Old Jan 31, 2016 | 04:04 PM
Gem frst's Avatar
Gem frst
STD ecu and injectors and converted xr2i loom with the pin changes
Old Feb 10, 2016 | 02:55 PM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
MAP sensor connected and a good vacuum signal?
Old Feb 23, 2016 | 05:42 PM
Gem frst's Avatar
Gem frst
Yes map sensor connected how do I check for a good vacuum signal?
It runs just very lumpy over fuelling ? Can smell it
Old Mar 13, 2016 | 05:50 PM
Gem frst's Avatar
Gem frst
Any ideas guys want to get this on the Rd now
Old Mar 13, 2016 | 06:29 PM
RSmark84's Avatar
RSmark84
What is the car idling at? I find Denso iridium IK27 plugs are better for the EFi turbo, With NGK mine idled worse. Have you cleaned the ISCV out with carb cleaner, Also clean out the throttle body too. the other thing to check is the CTS.
Old Apr 13, 2016 | 08:56 PM
Gem frst's Avatar
Gem frst
Plugs have been in before and ran fine have cleaned iscv out not made a difference have replaced co pot , Edis, injectors and fuel rail for known working ones new cold start valve still the same it's had a t3 conversion but still runs std injectors and ecu would this be a problem
Old Apr 14, 2016 | 12:21 PM
mentalasanything
Won't affect idle. Have you set the base idle? also, what breather?
Lee
Old Apr 14, 2016 | 06:47 PM
mentalasanything
Lee
I mention the breather as I had a similar issue. The issue I had was where I removed the breather system in favour for a mini K&N on the rocker cover; bad move. There are two vacuum ports on the lower inlet manifold, these take in fresh air and vapours from the breather system for idle.
Lee
Old Apr 15, 2016 | 01:12 PM
Gem frst's Avatar
Gem frst
Lee
Standard breather how do.you set base idle?
Old Apr 15, 2016 | 05:18 PM
mentalasanything
Have you connected the 2 vacuum outlets to the breather?
For the base idle there is an adjustment screw on the bottom left of the throttle body as you look at it from the front of the car (near the TPS). IIRC you need to disconnect the ISCV, hold the revs at 2k for 30 seconds and let them drop back. If the car cuts out turn the screw on the throttle body a quarter turn anti-clockwise.
Lee
Old Apr 18, 2016 | 07:14 PM
Gem frst's Avatar
Gem frst
For the base idle there is an adjustment screw on the bottom left of the throttle body as you look at it from the front of the car (near the TPS). IIRC you need to disconnect the ISCV, hold the revs at 2k for 30 I seconds and let them drop back. If the car cuts out turn the screw on the throttle body a quarter turn anti-clockwise.
Lee
Still no joy think the problem is that's it overfuelling mega and can't find out wy
Old Apr 18, 2016 | 09:30 PM
214_si's Avatar
214_si
Have you checked the fuel pressure at the rail?
Old Apr 18, 2016 | 10:24 PM
mentalasanything
Try disconnecting the pipe from the vacuum ports on the inlet to the breather at the breather end so that the pipe is open to air. Does it idle happily up high? If so the breather may be blocked. If not, remove the one way valve and repeat. The one way valve may be back-to-front or blocked.
Lee
James Porter
PassionFord Swap Shop.
Oct 16, 2016 07:53 PM
TuRbO-CaB-LaD
Feb 10, 2016 02:56 PM
original
Feb 4, 2016 04:00 PM
Bazars
Jan 31, 2016 04:44 PM
rapiddog
Jan 31, 2016 11:17 AM
