Whats needed for a coil pack conversion
Hi people got another thing i would like to do
What will i need to run coil packs
Iv got cosworth management
Running efi
But got the old distributor wont to replace it with packs
Anyone know whats needed for the conversion
Or is there a kit out there
Thanks all
Running efi
Thanks all
Speak to MSD about their wasted spark conversion. This will let use use a zetec coil pack. Individual coil packs is a pretty involved conversion on the RST and you would need to make up a suitable mounting bracket remembering that the exhaust manifold is 1 inch away.
Zetec coil pack is the sensible way forwards..... what do you hope to gain from the conversion?
Rob,
Rob,
its easy.
1. fit a cam sensor kit to the end of the cam pulley
2. extra ignition amp and sub loom. (buy one with rev counter fix built in. only one type i know will have)
that)
3. wasted spark board wired into the ecu.
4. the coilpack and bracket leads etc to be fitted.
gap the plugs correctly and enjoy the extra power with correct mapping.
that)
Thanks for that info spoke to them and thay sell the kit for 370 i think thay Said
Got a cam sensor as got cosworth management and a crank sensor to
Wont to go that way as more reliable in my opinion
Rob,
John 2.9
Nov 16, 2016 06:18 PM
SmudgerByName
Jan 10, 2016 03:14 PM
