Lambda problem
Old Jan 25, 2016 | 11:56 AM
mrmann's Avatar
mrmann
Default Lambda problem
I have a 1992 saph cossie. Ive fitted a new T34 and it doesnt have anywhere to put the lambda sensor. So i plan to weld a boss to the down pipe! Im not sure my lambda sensor is the right one as everyone says its a m18x1.5 thread buy its been measured at m12.1.25 thread. Anyone shed any light on this as i cant find a boss to fit it?
Old Jan 25, 2016 | 01:54 PM
Loomer's Avatar
Loomer
Its a simple difference in lambda sensors.
The OE one is the smaller type which you may have to make a boss for, quite simple to do.
The Larger one is a newer style lambda like the 3 wire Bosch we use which is m18x1.5 bosses are readily available for these.
Old Jan 25, 2016 | 02:14 PM
cossie2's Avatar
cossie2
You can get the OE one from Matt Lewis motorsport..
melpear
Ford Focus Range
Sep 8, 2017 04:18 PM
red sport
Ford Focus ST
11
Mar 24, 2016 01:41 PM
jacobwigley
Jan 31, 2016 07:12 PM
KAnne
Ford KA
Jan 23, 2016 03:33 PM
evoboy
Jan 19, 2016 07:48 PM
