Steering rack replacement
Old Jan 24, 2016 | 04:47 PM
cossie330's Avatar
cossie330
Default Steering rack replacement
Hi guys has anyone any tips on how to remove steering rack on 4x4 cosworth with aircon as one of the bolts holding the rack in seems to be obstructed from coming out by the aircon pump?
cheers jason
Old Jan 25, 2016 | 09:14 PM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
My guess would be to move the a/c pump but not sure as mine is non a/c.
Old Jan 25, 2016 | 09:49 PM
The Youth.'s Avatar
The Youth.
You need to remove the 4 mounting bolts from the pump but leave the pipes attached, then remove the mounting bracket as that's what the bolt hits (it does on an escort cos anyway but I'm certain its the same)
good luck! done mine a few times now and that's how iv'e had to do it
steve
Old Jan 25, 2016 | 09:55 PM
cossie330's Avatar
cossie330
Cheers, I'll give it a go at the weekend
newsh
Feb 21, 2016 11:18 AM
Jack and the Beanstalk
Jan 5, 2016 05:27 AM
Tim Wharton
Jan 2, 2016 08:39 AM
JanDK
Dec 29, 2015 03:33 PM
