Hello. I am new to this forum. I took ownership of a series 2 90 spec rs in summer. I have started a stripping the rear end ready for some light restoration. I have got the rear brake compensators out. I am struggling to remove the brake lines from them currently. If i cannot remove, what can i fit to replace this set up. I want to keep the rear drum set up and as standard as possible. There appears to b loads of info about bias valves etc( and in line valves from a ka) but i have no real idea what these are. Is there an idiots guide on what i can put in place if i cannot save the original compensators. I will be posting pics along the way so would appreciate comments and thoughts. ( ( (when i know how to do it from my phone gallery)Thanks
The best way is to remove all the brake lines and all components.
Then fit a 22 or 23 rating master cylinder 6 brake lines and the compensators at the front.
These are available from any non ABS mk3/4 escort apart from rs16i or LHD versions.
There are also kits available with full braided lines and compensators etc ready to fit.
I have the ka in line valves on my rs turbo and my track car ,removed all the rear compensator set up and mounted the in line valves on each rear chassis leg bracket,work a treat
Thankyou for replying. Much appreciated. Started off as a light resto but now ended up a full resto. J
There are also kits available with full braided lines and compensators etc ready to fit.[/QUOTE]
Thanks twins. I did find your thread and very interesting. Havnt made the decision on drums or disks now on the back. Car now almost stripped. Just engine and front suspension to come out
Around window
Been a bodge job previously. Plated over on both sides.
