Softlines
Old Jan 11, 2016 | 08:14 AM
polle90's Avatar
polle90
Default Softlines
Hello, i bought some mint 17 inch softlines for my mk4 cabrio.
Witch tyre size will goon these wheels:195/40 or 205/40?
Also witch wheel bolts i have to use? I am reading here ghia bolts?
Or they different? Or has someone a picture of these bolts?
Thanks
Old Jan 11, 2016 | 01:00 PM
polle90's Avatar
polle90
I have been offered tyres size 215/35-17.
Will this fit on an mk4 rs turbo cabrio?
Old Jan 11, 2016 | 07:12 PM
superbikerider1's Avatar
superbikerider1
I've got 205/40/17 on mine, and the bolts are the one with the washer/collar that can spin. Hope this helps!
Old Jan 12, 2016 | 06:57 PM
marky_g's Avatar
marky_g
Fleet Manager
I was going to use 205/40's on mine but being a 7.5 wide rim the 215/35 might be a better option
Old Jan 12, 2016 | 09:07 PM
superbikerider1
TBH the 205's sit right on my rims, the 215's wouldn't look right imo - but each to there own!
Old Jan 12, 2016 | 10:15 PM
marky_g's Avatar
marky_g
Fleet Manager
Being a 7.5 wide rim there desigined to take a 215, 205 gives you little stretch which is what id go for personaly but if hes getting 215/35 much cheaper they would work and not look to different
Old Jan 13, 2016 | 07:40 AM
superbikerider1
215/35 is such an odd ball tyre compared to the 205/40 I doubt they'd be cheaper. An the car would ideally take the 205/40 as oppose to the 215/35. Also, mine have no stretch at all with the 205/40 fitted.
Old Jan 17, 2016 | 04:16 PM
obrutsr09's Avatar
obrutsr09
205/40/17 on my s2,also used ghia studs got them from speed shack 3/4 years back
fordnutsboltsclipsscrews
15
Jun 22, 2022 06:05 PM
richbogle
12
Jan 26, 2016 04:50 PM
Ford Range
Jan 14, 2016 01:30 PM
