hard boot on Sierra cosworth 4x4
Old Jan 9, 2016 | 09:36 AM
Frenchi Dav's Avatar
Frenchi Dav
Default hard boot on Sierra cosworth 4x4
Hello
I apologize in advance for my pitiful English because I am French and I use a web translator.
I own a Ford Sierra cosworth 4x4 1990 blue-moonstone.
a my car for a few days starting difficult.
A cold when I put the contact for the start, the engine puts this property launches an engine speed I very very very low, sometimes limit caller.
I thought it might come from the probe temperature water (blue), I changed it but the problem remains the same.
The engine runs well on all 4 cylinders so it quoted no apparent problem.
slowed the valve has no operational difference whether connected or not. Are this the problem ?
Thank you
Old Jan 17, 2016 | 06:16 PM
martysmartie's Avatar
martysmartie
The CTS (blue sensor) is used for fuelling.
The ISCV (white top) is what controls the engine speed, there is a base idle and it can raise it above this, when required.
However, does not affect the idle when up to temperature, if it does then your base idle needs setting up correctly. This would also cause problems when cold.
Martin
Uncle Henry
Dec 31, 2015 04:26 AM
Nov 25, 2015 08:11 PM
dom1188
Nov 20, 2015 04:29 PM
CosoyDimas
Nov 13, 2015 04:01 PM
