Borgwarner T5 to electronic speed sensor?
Old Jan 6, 2016 | 11:14 AM
DixieTheKid's Avatar
DixieTheKid
Pick-up P100 Power!
Default Borgwarner T5 to electronic speed sensor?
Hello peeps,
I've had a good search but with no real results that i can find. I'm trying to find out if i can get an adapter to convert the T5 speedo drive to an electronic speed sensor. Ive spoken to Burtons and they couldn't help me and I've also spoken to CTS (gearbox man) however they are going to look into it and I've got to ring back later.
I'm trying to find out if this is possible, if not ill have to change the instrument crusher in the Focus more suited to the cossie engine & box.
OR, has anyone done this? What adapter and sensor did you use please?
Regard's,
Chris
Old Jan 11, 2016 | 07:27 PM
3doorcozmess's Avatar
3doorcozmess
any luck
Old Jan 11, 2016 | 07:30 PM
DixieTheKid
Pick-up P100 Power!
Not yet. I'm told burtons do an adaptor which works. Worth a punt I reckon
Old Jan 11, 2016 | 08:10 PM
focus 4x4's Avatar
focus 4x4
I'd be interested to hear how you get on with this , I wish you luck
Old Jan 11, 2016 | 10:14 PM
fraser9764's Avatar
fraser9764
http://www.burtonpower.com/ford-elec...or-revfss.html
http://www.burtonpower.com/revotec-e...x-revt9-a.html
This one? looks interesting. Let us know how you get on. I've mounted a sensor to the front hub which picks up on the back of the wheel studs which works fine. But that's a much neater solution if it works.
Old Jan 12, 2016 | 04:16 PM
hEaT's Avatar
hEaT
The 94-98 Mustang used a VSS in place of the speedometer. Has anyone tried fitting the OEM Ford piece?
http://www.rockauto.com/catalog/more...nid=626&jpid=0
Old Jan 12, 2016 | 07:08 PM
DixieTheKid
Pick-up P100 Power!
The one in that link looks very different to a t5 machanical one.
Old Jan 25, 2016 | 11:13 AM
oohogwash1's Avatar
oohogwash1
Any luck on this ?
Old Jan 25, 2016 | 03:05 PM
surrey_100e's Avatar
surrey_100e
I got mine from burtons, works fine
Old Jan 26, 2016 | 03:03 PM
DixieTheKid
Pick-up P100 Power!
Originally Posted by surrey_100e
Perfect! Thank you.
Old Jan 26, 2016 | 04:31 PM
adam151082's Avatar
adam151082
my speedo doesn't work as that worm drive thingy is knackered, with the fix it? or is this just to replace the cable?
Dean Guest
Ford Focus ST
Mar 8, 2016 08:36 AM
nickscunny
18
Jan 11, 2016 11:17 AM
Fil
Jan 1, 2016 12:47 PM
DixieTheKid
Dec 31, 2015 01:54 PM
