which injectors after beiges on ofab
Old Dec 30, 2015 | 08:55 PM
beaver rs 88's Avatar
beaver rs 88
in the garage
Default which injectors after beiges on ofab
Not posted for a while but here goes.... I converted my series 2 to ofab efi last year and had a custom chip made on the rollers at MSD. They said that I should get my beiges cleaned and flow tested as I was running lean after 5k rpm. I had this done and the car is currently running 193bhp on their rollers. I took the car to the ring last summer and to SPA aswell and noticed it was running hot on the track. I am wondering if the injectors are still not upto the job as I'm running 3bar standard fuel pressure but MSD advised I should get bigger injectors rather than upping the fuel pressure and running my injectors flat out. So what injectors can I use now? Tried searching but haven't come up with anything. Sorry for the long post.
cheers nick.
Old Dec 31, 2015 | 08:25 PM
mentalasanything's Avatar
mentalasanything
cheers nick.
There won't be much info out there if any as beiges are usually the lot on OFAB/OFAC with off the shelf chips. Obviously you'll need a remap so I'd go with the mappers advice, you could use one of many Bosch EV1 injectors.
Lee
Old Jan 8, 2016 | 11:22 AM
Karl @ FPT's Avatar
Karl @ FPT
Always a pleasure!
I'm sure MSD can map it to use either VXR injectors or DEKA IV's, just give Stu a call mate.
Old Jan 12, 2016 | 01:41 PM
beaver rs 88
in the garage
Cheers Karl I will give them a call when I get chance
rs_jim
Fiesta XR2
May 3, 2016 07:22 PM
Rst tyrone
Feb 25, 2016 06:21 PM
paceo
Jan 5, 2016 06:59 PM
Ridgey
11
Jan 4, 2016 06:13 PM
