Does this wiring diagram look correct?
Old Dec 29, 2015 | 12:31 PM
muz's Avatar
muz
Wye Valley Hardcore
This is the diagram I drew up when I built my loom. It's running L8, with wasted spark, 2WD on a PF09. Can anyone have a quick look and tell me if it all looks ok before I try fire it up. I've already reversed the TPS wiring as it was reading backwards wired like this and I've also reversed the Air Injector pins so 12v goes to pin 1 and ECU Earth feed goes to pin 2 on the JPT connector but what about everything else?
Old Dec 29, 2015 | 02:04 PM
Sierrasideways's Avatar
Sierrasideways
No picture mate
Old Dec 29, 2015 | 04:03 PM
muz's Avatar
muz
Wye Valley Hardcore
Oooops
Old Dec 30, 2015 | 09:17 AM
cossirob's Avatar
cossirob
wow hats off to you muz i think many people will find the very helpful. If i tried to draw that it'd be a right mess lol
Old Dec 30, 2015 | 11:03 AM
Ridgey's Avatar
Ridgey
Compare to this web site, has all diagrams on it.
http://www.bigturbo.co.uk/main6.htm
Old Dec 30, 2015 | 02:52 PM
Why do some cars run 2 ignition amplifiers.
Old Dec 30, 2015 | 03:00 PM
s1cosse's Avatar
s1cosse
Twin amps for wasted spark mate.
Old Dec 30, 2015 | 03:04 PM
s1cosse's Avatar
s1cosse
That looks spot on muz.
Old Dec 30, 2015 | 04:43 PM
muz's Avatar
muz
Wye Valley Hardcore
Turns out the TPS wiring was correct first time around after plugging the Collins Monitor in lol.
Albertodelgado
108
Feb 4, 2018 09:44 PM
Matt478
Jan 2, 2016 08:50 PM
batrst
Ford Focus ST
Dec 23, 2015 11:24 PM
RIB1122
Dec 23, 2015 01:14 PM
batrst
Dec 23, 2015 03:02 AM
