Autospecialists power steering hose
Old Dec 27, 2015 | 03:46 PM
Adam-M's Avatar
Adam-M
Default Autospecialists power steering hose
Hi there
Does anyone know if the following power steering hose from AS that allows you to fit the AS inlet is the supply hose from the power steering reservoir to the pump? ...
My supply hose is badly worn and I need a new one and my future plan is to fit an AS inlet, so the the above hose replaces my worn hose and allows you to fit the AS inlet then I'm onto a winner.
The bigger hose in the following pic is the one in wanting to replace...
Old Dec 27, 2015 | 05:06 PM
Albertodelgado's Avatar
Albertodelgado
yes mate that is the correct hose I just fitted mine a while ago for the same reason to get rid of the old one and because I could fit the new inlet.
Stephan
Old Dec 27, 2015 | 05:11 PM
Adam-M's Avatar
Adam-M
Thanks alot for that mate 2 birds 1 stone lol
Old Dec 28, 2015 | 03:12 PM
Ridgey's Avatar
Ridgey
What was the purpose of the loop in the original?
I'd also like to replace my original, but not fitting AS inlet, this one is much tidier though.
Old Dec 28, 2015 | 10:53 PM
Adam-M's Avatar
Adam-M
Ridgey I'm guessing it's for clearance for something I don't really know.
This is why I'm replacing mines...
It looked nice and fresh until I straightened it, I dunno what made me check but I'm glad I did. Had the full front end off to replace the oil pump and sump gaskets...
Old Jan 3, 2016 | 06:25 PM
Cossy Mike's Avatar
Cossy Mike
It needs the kink in it cos it acts like a spring when you tension the PS belt up
Old Jan 4, 2016 | 12:57 PM
Ridgey's Avatar
Ridgey
Perhaps the silicone hose is far more flexible and gives the required movement without ?
Old Jan 5, 2016 | 07:32 AM
Cossy Mike's Avatar
Cossy Mike
The AS pipe is for the hart plenums, for clearance on the throttle body
Old Jan 5, 2016 | 04:40 PM
Ridgey's Avatar
Ridgey
That was stated in the opening post
The hose still needs to be suitable for its job.
Old Jan 6, 2016 | 11:21 AM
Adam-M's Avatar
Adam-M
Got the hose delivered yesterday ridgey I'll fit it this weekend and see what it's like, it's defo less flexi than the original.
Kevin'
Mar 22, 2016 10:07 PM
Drebin
Dec 31, 2015 01:41 PM
townie9371
13
Dec 24, 2015 07:52 PM
BigBez
Ford Focus Diesel
Dec 20, 2015 05:28 PM
