PassionFord FAQs This is a collection of frequently asked questions... "How do I become Gold?" "How do I post pictures?"
Oil Cooling
Old Dec 24, 2015 | 01:59 PM
cpur's Avatar
cpur
Default Oil Cooling
Hi Guys,
First of all happy Christmas to all.
I am fitting an oil cooler on my yb , Usually used for hillclimbs but will go for some track days next year so i am preparing my Car.
I am using the conventional thermostatic sandwich plate with the outlets that go to an oilcooler, however when removing the original oil/water heat exchanger the sandwich plate sits so deep that it is practically imposible to route the pipes to the cooler . This install is on a Mk2 escort so not much engine bay space. However if i leave the heat exchanger things get much easier. On google i found that evos use a kind of spacer when doing this install.
Would you guys go for a spacer of this kind or else leave all the heat exchanger system and undisturbed water system in place and then add the sandwich plate system to it.
I was also thinking that this might aid the water cooling, which is a good thing for me as my radiator is at the back, and quite critical.
Any suggestions?
Thanks
Cpur
Malta
Old Dec 24, 2015 | 02:51 PM
lacey's Avatar
lacey
I my self would/have removed the sandwich heat exchanger ( modine I think it's called )
I also don't run water through the turbo ( but so do require it )
As for a spacer , if you need one then you need one
Just make sure it has no sharp edges for the oil to pass over .
How have you got on with the rad in the boot as my rad is in the boot of
My 3dr sierra
Old Dec 24, 2015 | 10:25 PM
cpur's Avatar
cpur
rad in boot, i bought the car like that, had some problems with it but due to the plumbing not routed correctly, now all seems good but , never been to a track only raced for 60 second hillclimbs.
Old Dec 28, 2015 | 08:35 PM
cpur's Avatar
cpur
Hi.
I removed the modine. Quite a job to get the oil pipes out off there .but will have to.
I read that if the plate is thermostat controlled ,one doesn't need the modine.
Thanks for all.
simontrayler
Mar 22, 2016 09:45 PM
cpur
Feb 22, 2016 06:44 PM
muz
Nov 13, 2015 07:03 PM
4x4kiwi
Nov 11, 2015 01:01 PM
gingeRS
Oct 25, 2015 11:33 AM
