ST170 PCV Feels loose
Old Dec 24, 2015 | 11:49 AM
Pitbull69's Avatar
Pitbull69
Default ST170 PCV Feels loose
Replaced my PCV valve on my ST170 yesterday, but the new one moves quite easily, if it wasnt for the rubber pipe on the end I think it could quite possibly fall out,
Looking online they say it should be a snug fit, Can the rubber pipe the PCV valve sits in be replaced ?
Or does anyone have any suggestions how I could make it tighter, I thought maybe some kind of tape around it, but dont know if it could perish and do damage later on.
Old Dec 24, 2015 | 01:03 PM
STeve's Avatar
Super Moderator
prob needs new holder
Old Dec 24, 2015 | 01:06 PM
Pitbull69's Avatar
Pitbull69
Are they easily replaceable ? and would you happen to know the exact name, or part number ? Google isnt in the mood to help me today,
Old Dec 24, 2015 | 01:13 PM
STeve's Avatar
Super Moderator
due to their location they can be a fiddle but are straight forward, I simply call them a crankcase breather valve grommet
Old Dec 24, 2015 | 01:15 PM
Pitbull69's Avatar
Pitbull69
Thanks mate, Will wait till Fordparts UK are back off holiday, and see if they can find it.
Old Dec 24, 2015 | 01:17 PM
Pitbull69's Avatar
Pitbull69
Sorry forgot to say, do you think car wil lbe drivable while its like this ? I dont need the car much, just new years eve shopping etc,
Old Dec 24, 2015 | 02:15 PM
RichieST's Avatar
RichieST
Use this site for all your part numbers!
http://eucatparts.com/?action=cat_ford
Old Dec 24, 2015 | 02:25 PM
Pitbull69's Avatar
Pitbull69
Thanks mate, so looking at this, I need a HM1
Old Dec 24, 2015 | 02:33 PM
STeve's Avatar
Super Moderator
wont really effect how it runs in fact may make it run better lol as its only a bugger when its blocked or siezed
Old Dec 24, 2015 | 02:41 PM
Pitbull69's Avatar
Pitbull69
Cars been an absoloute nightmare lately, changed everything I can think of, spark plugs, Coil pack, various sensors, MAF etc, but when cruising car seems to feel jurky, Garage told me to change PCV and see if it made a difference, the old PCV wasnt blocked, but it did look worse for wear, If this doesnt fix it, im gonna have to take it to a garage and get a smoke test done on it, as getting sick of the kangerooing,
I keep getting my EML light flash on and off, but 2 garages cant find any fault codes coming up at all, so not sure what that is either.
Old Dec 24, 2015 | 04:37 PM
STeve's Avatar
Super Moderator
IMRC is main cause of most running issues with 170s or filthy throttle flaps which stick or even a speed sensor
Old Dec 24, 2015 | 05:23 PM
Pitbull69's Avatar
Pitbull69
Had a Brand new IMRC fitted just before I bought the car, its been checked at garage and all working as it should be, Just had a brand new CFM 67mm Throttle Body and new Throttle Position sensor put on too,
Car feels good when foots down, its just a kangeroo when I try and cruise along, I have got a split in my cat, but garage said that shouldnt effect running of the car.
Decat will be fitted after xmas, just waiting for my new manifold to arrive,
Old Dec 24, 2015 | 05:40 PM
STeve's Avatar
Super Moderator
I will be breaking a high spec 170 with a miltek decat and stainless 4 branch and scorpion cat back in the new year but i guess too late for you, if your lambdas are checked a crumbling cat can cause issues, but to be honest I would have checked it on a diagnostics machine before throwing a penny at it
Old Dec 24, 2015 | 05:45 PM
Pitbull69's Avatar
Pitbull69
Unfortunatly yes, Got an RS Mongoose Exhaust on, Already got my decat here, but because of an after manifold it didnt fit, so going to revert back to a standard manifold, Both Lambdas are brand new, I did have a look in the cat when it was removed the other day, but al lI could see was a honey comb, unless its breaking up on the otherside to where I was looking,
Just really hope I get to the bottom of it soon, as much I like putting my foot down, it would be nice to be able to cruise with looking like a learner driver,
Have had 2 garages look at it, with diagnostics and not come up with anything, Also had the RAC look at it, for all the good they did, told me my lambda was at fault, when it was my MAF that had failed,
Old Dec 24, 2015 | 06:14 PM
STeve's Avatar
Super Moderator
when I say diagnostics machine I mean somebody of the likes of MSD etc, but defo sounds like the car is giving you the runaround, the fact the eml comes on can only really point to a few things, and sounds like you have covered the usual suspects as last resort would be a ecu but again get a pro like MSD to check it
Old Dec 24, 2015 | 06:36 PM
Pitbull69's Avatar
Pitbull69
Garage said EML can come on and off because theres an issue thats not quite enough to bring up a code. not sure how true that is,
I have a Bluefin remap on the car, so if this PCV valve hasnt made any difference I will put it back to standard, and see how that goes,
Do you know how I would find a local Pro like MSD local ish ? I have been in touch witha few remap places that have said they can remap my car to make it run with all my modifications, but not sure I want to go ahead if it sounds like I have a possible faulty ECU
Old Dec 24, 2015 | 07:21 PM
RichieST's Avatar
RichieST
If you are leaking exhaust gases before either the pre or post cat lambda sensors, this will give you running issues. The pre cat lambda is a common fault on these and do give the symptoms you describe, I would get the exhaust fixed first then look into changing this.
Old Dec 24, 2015 | 08:41 PM
Pitbull69's Avatar
Pitbull69
Thanks Guys some great advice here, Leaking before Post cat lambda. this is all getting fixed in the new year, So will go from there, Thanks again. Much appreciated
Merry Chrimbo
Old Dec 24, 2015 | 08:43 PM
STeve's Avatar
Super Moderator
msd are in blackpool but being a londoner dont have a clue of anyone else up your way
Old Dec 24, 2015 | 08:45 PM
Pitbull69's Avatar
Pitbull69
Im a Londoner too, Just got lost up Norf one day and never went home lol..
Will see howe exhaust being fixed goes, and then decide from there what im gonna do, Might be cheaper to buy a replacement ECU, that travel all the way to blackpool and back,
Old Dec 24, 2015 | 09:06 PM
mattxr3i's Avatar
mattxr3i
What is the diameter of standard throttle body. 67mm sounds like a huge increase and could be causing a lean mixture at part throttle.
Old Dec 24, 2015 | 09:14 PM
Pitbull69's Avatar
Pitbull69
Its not a big difference I thought the standard was 65mm but google just came up with 66mm, either way I dont think its a huge difference, and the car was behaving this way before I swapped the throttle bodies over, I only swapped them as I squashed my standard plastic throttle body over tightening my Induction kit.
Old Jan 2, 2016 | 02:00 PM
Pitbull69's Avatar
Pitbull69
Thanks for the advice guys,
One brand new PCV and grommet now fitted, With slightly mashed fingers, (was right about the tighut space lol)
Old Jan 2, 2016 | 02:02 PM
STeve's Avatar
Super Moderator
done a few of these in the past and once even had to drop manifold
Old Jan 2, 2016 | 02:04 PM
Pitbull69's Avatar
Pitbull69
I was debating waiting till the cars in the garage in a few weeks having manifold swapped and decat put on, but managed to put a flat head into the side of the grommet and it lifted enough I could get a grip with the pliers, wasnt worried about damaging the grommet knowing it was being replaced,
But its all tight and fitting snug now, so hopefully wont need to be touched for a while now,
Going to wait for the decat to be fitted then if I still have running issues get it smoke tested for any other leaks
perm1
22
Jun 8, 2016 07:59 AM
Tim Wharton
Music & Car Audio Chat
Dec 20, 2015 02:40 PM
dirtysteve
Ford Focus ST
Dec 16, 2015 04:06 PM
morg65
Escort Range
Dec 8, 2015 07:44 PM
mgs41987
Ford Focus ST
11
Dec 6, 2015 07:22 PM
