2.9 V6 4x4 Low idle while rolling to a stop. Standstill fine. Also over cooling.
Old Dec 17, 2015 | 05:37 PM
Graham S1's Avatar
Graham S1
Default 2.9 V6 4x4 Low idle while rolling to a stop. Standstill fine. Also over cooling.
Suggestions for fixes please?
I'm pretty sure the over cooling is leading to the first problem. When running around twon etc, the gauge never gets above the top of the white block at the bottom of the gauge. If on a long run (ie motorway), it will drop to the bottom of the white block.
Viscous fan spins freely, not seized. There is a thermostat in there (put a new one in just in case while housing was off).
Replaced the VSS, but no change there.
Car is also a bit lumpy pulling away hard, or going up hill.
What else is there to check / look for. Car was serviced fully not long after I bought it a few months ago.
Old Dec 18, 2015 | 10:55 AM
dojj's Avatar
dojj
Resident Wrestling Legend
2 very easy things to check/change
First is the temp sender, once they go past a predetermined level they never read right again so change it, they are around £11 from ford but you need to get the correct one for your car, not based on what the colour ring is at the top
Secondly, remove the air box so that you can access the flaps inside the air flow metres, push these flaps with your fingers to check for any resistance or unevenness in the movement
You shouldn't be able to plug then back in the wrong way either but don't discount that
Old Dec 19, 2015 | 03:49 PM
Graham S1's Avatar
Graham S1
Cheers Dojj
The coloured ring sender is for the dash, yes? That won't make any difference to what the engine does? The big fat one next to it is for the ECU?
Flaps move nice and freely. When I first bought the car and gave it the once over, one of the flaps was stuck solid. Had the unit apart, and got some lubricant into the spindle, so now it moves and springs back easily. White plug in the front meter, black plug in the rear one.
Old Dec 20, 2015 | 09:44 PM
dojj's Avatar
dojj
If the temp on the dash is wrong it can give you thoughts of stuff going wrong that might be fine
If anything they tend to run hot with the viscous fan
The flap issue might still be the cause, get a meter on there to see if it's working properly rather than just moving freely, the tracks can cause issues
Unfortunately you can't put a fault code reader on then
Old Dec 24, 2015 | 02:01 PM
Graham S1's Avatar
Graham S1
Ha! And duurrrrrr....
Forgot I hadn't rechecked CO after rebuilding the top end a few weeks ago. Was reading minus figures on the CO meter. Wound the screws out a bit, which made it worse. Wound them all the way back in until they stopped, and CO went to 1.2% ish which isn't too bad. This has now stopped the near stalling, so it was probably running way too rich.
Anyhoos, seems to be fixed now. Be interesting to see if theres an improvement to mileage, was only getting about 270 out of a tank.
Old Dec 24, 2015 | 04:18 PM
dojj's Avatar
dojj
As much as that!!!!
jc1989rs
Dec 23, 2015 11:05 AM
bear
Dec 14, 2015 09:03 PM
Adam-M
Dec 13, 2015 05:33 PM
bigdel
Dec 13, 2015 10:10 AM
