Fuel cut out.
Old Dec 15, 2015 | 07:59 PM
muffster's Avatar
muffster
Default Fuel cut out.
The fuel cut out switch in the spare wheel well. Does anyone know how they are removed and how the wires disconnect?
I want to take mine out but cant quite work how its done. I don't want to disturb anything before i know exactly how to do it.
Cheers.
Old Dec 17, 2015 | 07:09 PM
muffster's Avatar
muffster
Come on folks, 169 views but no reply.
Someone must have taken one out before.
Old Dec 17, 2015 | 07:42 PM
cozzy jeff's Avatar
cozzy jeff
aren't they riveted to the boot floor?think I'd trace the wires back from the switch you may find a plug under the seat.
Old Dec 17, 2015 | 07:48 PM
martysmartie's Avatar
martysmartie
I suspect it may be wired directly to it. You would think it could be removed, so a replacement could be fitted.
Martin
Old Dec 18, 2015 | 05:36 PM
muffster's Avatar
muffster
Yes its riveted to the floor but the wires are only short wires and i obviously dont want to pull the fuel cut out away from the wheel well to look at the wires underneath it.
Old Dec 18, 2015 | 06:13 PM
daz-cos's Avatar
daz-cos
The frame is riveted but you can take the switch out of the frame, and if memory serves there's only to wires from it so just cut and join them together to do away with it.
155lee
Feb 7, 2026 06:07 PM
Rs Gus
Dec 23, 2015 12:55 PM
Mark V8
Wheels and Tyres
31
Dec 22, 2015 09:44 PM
admiral
12
Dec 13, 2015 06:28 PM
4x4kiwi
Nov 28, 2015 06:11 AM
