Cosworth and mk1 escort parts clear out
Delivery extra, agreed price to be paypaled , fees are up to buyer, have credit in your account and no fees I believe .
Saff Cosworth genuine headlamps and wipers/motors. SOLD
2x Cosworth alternators ,one with rare heat shield. 60/75 with shield
Cosworth rear arms with brand new ford bearings 100
3dr rear inner bulb light assembly. Bnib 40
Cosworth air box,opened up for extra airflow/power. 25
Cosworth std air box. SOLD
Cosworth Jamex foam filter for std air box. 10
3dr fiberglass vents. 30
Sapphire rear Amber, bnib 60
Cosworth 2wd inter cooler good. 30
Cosworth escort chargecooler. 60
Sapphire Cosworth fog lights pair, good. SOLD
Sapphire Cosworth fog lights reflectors bnib, some surface staining 30
Pair of compition seat bases. 30
Cosworth alloy sump. (Rs2000???) SOLD
Cosworth workshop manual ford. SOLD
Bosch 0044 x2 to 400bhp. 90 each
Bosch 0023 std. 30
Cosworth 2wd rear calipers 30
2wd Lhd quick rack 2.5. 100
Clutch release arm 10. SOLD
Bell housing rubber plug. 5
Turbo exhaust studs/bolts 20
Mike R camber shims rear 10. SOLD
Sierra fuse cover 10
Cosworth 2wd throttle body 80
Cosworth chrome cam wheels 20
-31 actuator SOLD
Sierra Cosworth Amber fronts,slight chip in one corner. 50
Cosworth 2wd ford/Ap clutch discs 50 each
Cosworth top suspension polys and chrome caps 20
T3 turbo hanger 10
Cosworth Sierra abs sensors 25
Three Cosworth Sierra throttle cables , one bnib ford. 20/20/30
Cosworth fuel rail. 30
Cosworth fuel rail wiring chrome cover. 20. SOLD
Sapphire cos outside window rubbers x 2
7"x17" et13 Revolution Motorsport Gpa alloys , seven of 490
Escort MK1
Works indicators 100
Rear reversing lights SOLD
Bilsteins rear pair 50
Rear shock mounts and bottoms brackets 15
Auto pedal box 15
Front shock inserts. 20
Mk1 quarter bumpers. 120
Mk1 brand new headliner black. SOLD
Mk1 front dog bone grill v good. 150
Steering wheel cowl v good. 20
Brand new GP4 alloy rad. SOLD
Mk1 escort seat bases (I think). 25
Gp4 escort hydraulic pedal box. Brand new 250
Gp4 accelerator pedal for above. Brand new 30
Hydraulic reservoir bottles and bracket tray brand new 60
Pinto 2000 with twin choke/k&n. Plus four branch ,starter,alternator, everything ready to drop in and run, 500
5 speed for the 2000 pinto 200
Toyota avensis 5 stud steel wheels bnib
Bnib wheels trims for the above,genuine Toyota 125 for the lot
click here for pics album
http://smg.photobucket.com/user/5555...r%20out%20pics
Bosch 0023 std. 30
-31 actuator SOLD
T3 turbo hanger 10
Escort MK1
Auto pedal box 15
Interested in wipers & motors, Don't really need the headlights.
PM me a price on both anyway in €.
Also interested in standard Air-Box.
Which side is the BNIB Light?
Can possibly collect depending where in Cork you are.
wipers/motors 20
will check rear amber
airbox reserved
first with money buys tho
I'll take the 2wd clutch release arm and the chrome fuel rail cover. Would you have a 2wd clutch release bearing as well. I'm Athlone, Co Roscommon would you post. Text your phone earlier 2day, No reply. Cheers Dave
