st170 iffy steering
Old Dec 12, 2015 | 07:43 PM
dirtysteve's Avatar
dirtysteve
Default st170 iffy steering
hi folks, my st170 seems to have a strange tight spot on the steering when cold, it only lasts for a mile or so then it's fine, has anyone any ideas?, thanks, steve
Old Dec 13, 2015 | 06:26 AM
STeve's Avatar
Super Moderator
have you checked the oil as it may need changing also a worn out track rod end siezing
Old Dec 16, 2015 | 02:33 PM
mcst's Avatar
mcst
Replace the fluid as a short term measure, ours had broken down and was like oil. Long term it's a new rack.
We had the fluid done and some sort of treatment added, cured it for about a year but when winter set in it was back. Fairly common problem with focus generally.
Old Dec 16, 2015 | 04:06 PM
Mine had a tight spot when turning left. Once the car was warm it was ok. I changed the steering rack and its beem spot on.
I got a recon rack off ebay for 120 quid.
bigmac490
Dec 19, 2015 07:58 AM
mgs41987
Ford Focus ST
11
Dec 6, 2015 07:22 PM
Chopshop85
Dec 2, 2015 07:20 PM
stu21t
Nov 22, 2015 09:22 AM
Fonzy
Ford Focus ST
Nov 13, 2015 11:30 AM
