Rear drums - series 1
Old Dec 9, 2015 | 08:51 PM
Phil_rs1800's Avatar
Phil_rs1800
Default Rear drums - series 1
Hi,
I have recently purchased a series 1 which has a rear disc conversion. I'm looking to change this back to drums. Are the series 1 drums different to other mk3 or mk4?
Old Dec 9, 2015 | 08:56 PM
studabear's Avatar
studabear
IIRC the series 1 had mk3 xr3i drums and hubs. the smaller engined mk3 and mk4 had the drums with the hub built in.
Mk4 xr3i drums and hubs might be the same as mk3
Series 2 Rs turbo had bigger rear drums, unique to the Series 2.
Old Dec 9, 2015 | 08:59 PM
Phil_rs1800
Can the series 2 drums be easily fitted to the series 1?
Old Dec 10, 2015 | 06:25 AM
studabear's Avatar
studabear
Can't see why not, but I have seen people post on here that the brake spring kits are obsolete or very difficult to find.
Old Dec 10, 2015 | 06:50 PM
Chas's Avatar
Chas
AFAIK, yes but I would suspect it would be easier to buy the hub and backplates for the conversion ; I am running a set on the rear of mine. According to a well known RST tuner he rates these more than the disc conversion which may be a little controversial!
I can check a few things if you wish. I think the hubs may be the same but I cannot say for sure. This is a pic of mine when I took the drum and hub off for the new bearings:
However, studabear makes a good point ; my springs (of a TRW brand) are a swine to fit to what I was taking off (sizes are wrong). I do plan to see if there is a correct supplier out there.
Old Dec 10, 2015 | 07:09 PM
mentalasanything's Avatar
mentalasanything
Hi,
Out of interest, what are you running for front brakes and why are you changing the rears for drums?
Lee
Old Dec 10, 2015 | 09:22 PM
Gadget's Avatar
Gadget
Spanner monkey
If you really want drums and are not in too much of a rush, I am building a series one track car for someone on here soon. It's got the full rear drum set up still on it with all new linings etc.
I'm sure he'd do you a really good price on the lot, may even px against the disc conversion.
Old Dec 10, 2015 | 09:53 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Lee
Must be for originality. I run discs on the rear of my S1 with a bias valve (done properly) and I wouldn't go back to drums. Car feels a lot more solid under braking now.
anthony lea
Dec 8, 2015 02:36 PM
JFB Tech
Dec 5, 2015 08:31 AM
Andyrangy
Dec 3, 2015 01:48 PM
Gmol30
Nov 27, 2015 09:53 PM
The Crocodile Hunter
Nov 17, 2015 07:56 PM
