On my 6000 radio it says it's locked,I have the code but can't get the code to come up on the display because I can't get the locked of the display any ideas what I should do cheers all
it will only say locked if the code has been entered wrong a certain number of times, sometimes simply holding button 6 will let you enter code again if not just bin it as they are cheap enough nowadays as ford would want more than its worth to rectify it
