Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
PCV Valve.? Can anyone tell me where it is.?
Old Dec 1, 2015 | 12:01 PM
morg65's Avatar
morg65
Default PCV Valve.? Can anyone tell me where it is.?
Hi all,
Any ideas where the positive crankcase vent valve is located on my mk5 xr3i 1-8.?
I am getting a little blow back of oil in the bottom of the air filter housing and suspect its clogged or needs replacing.
Thanks as always,
Morg.
Old Dec 2, 2015 | 06:06 PM
werdas's Avatar
werdas
On block under thermostat housing
Old Dec 8, 2015 | 07:44 PM
morg65's Avatar
morg65
Thanks dude,
Are you sure.?
Figured its in the oil separator on the side of the block.
Thats the problem with these engines..So many versions from 1991 to 2000.
eddie8987
Ford Fiesta
Dec 7, 2022 07:30 PM
comptoncjs2
Jan 21, 2016 05:36 PM
cossie09
Dec 9, 2015 03:23 PM
fordsteve77
Escort Range
Nov 27, 2015 11:27 AM
JoeyBoyden
Nov 26, 2015 05:25 PM
