Rev counter not working
Original clocks Rev counter doesn't work but the replacement one does, can anybody tell me what to look at as I would like to put back the original clocks as the mileage is different?
What year is the car? 89 spec is easy, 90 spec cars, just as easy, 92 spec car proper pain in the arse
Steering cover off
4 screws for the dash surround
4 screws for the instrument cluster
Then struggle to unclip the speedo cable
Easy to do the rest
92 spec cars are way different and if it's not find right you'll break the surround and never get it right again
Steering cover off
Easy to do the rest
Steering cover off
Easy to do the rest
Steering cover off
Easy to do the rest
they might be under some covers
they should just pop off or there are little caps on them and then the covers are screwed on
either side of the column underneath the little blanks (or the dash illumination/wiper motor intermitant speed)
cossie09
Nov 15, 2015 06:13 PM
Quaver
Nov 3, 2015 01:32 PM
