MK3 Mondeo 1.8 petrol, strange fault/fix
Old Nov 19, 2015 | 08:26 PM
gordyshreds's Avatar
gordyshreds
Default MK3 Mondeo 1.8 petrol, strange fault/fix
Hoping someone can shed some light on this so i can work out a way forward...
2004 1.8 petrol Mondeo.
Sometimes the car is hard to start, takes a while cranking and eventually kicks in, sometimes with a bit of throttle. Does always start in the end.
Now If when i turn the car off, as i switch off i press the accelerator to the floor, the car will ALWAYS start on the button the next time I go to start.
So by opening the throttle as the car shuts down, what is this doing and what do I need to do? Would it be a release (EGR?) valve not clearing the inlet/throttle body?
I have read on forums about the accelerator pedal as you turn off trick as it seems a common problem....just no one has said why!
Many thanks
Gordy
Old Nov 19, 2015 | 08:33 PM
RichieST's Avatar
RichieST
Check the manifold flap control hasn't come off. Look under the hose between the air box and inlet. You will see a yellow ball valve with a clip thing on top. I had a mk3 mondeo a few years ago and the clip kept coming off making it a bit hesitant at times.
orbital
Ford Focus Diesel
Sep 25, 2016 03:59 PM
Hammerman21
Nov 27, 2015 10:28 PM
cozzzzy power
Nov 18, 2015 08:41 PM
fuzzy
Oct 26, 2015 09:25 PM
