Escort Range Ford Escort RS1600i / Mk. 5 & 6 / XR3 Discussion.
Aaarrgghh.... This starting/running XR3i MFi k-Jetronic doing my nut in
Old Nov 17, 2015 | 12:16 PM
fordsteve77's Avatar
fordsteve77
Default Aaarrgghh.... This starting/running XR3i MFi k-Jetronic doing my nut in
Fault:
ignition on pump primes, fuel at metering head, fuel warm up and injector pipe on metering head (pic below)
As soon as it starts 2 seconds cuts out stalls....
The car ran before but ran rich and idle was a bit high and never dropped after the engine warmed up, BUT it did not have a Fuel Pump Relay see below
Things if done to the car since buying it in October:
New plugs/HT leads
New coil
K&N air filter
oil and filter change
injector cleaner in tank
2 replacement Fuel Pump Relays Purchased 1 original purple & 1 new Lucas, Have tried both of them as previous owner did not have one fitted he had Ignition live going to relay holder to constantly run pump and could hear the pump a little noisy.
Have cleaned the air sensing plate or whatever its called that sits with the fuel metering see pic
Any help most appreciated or is there anybody in kent that specialises in K-Jectronic fuel injection system
Attached Thumbnails Aaarrgghh.... This starting/running XR3i MFi k-Jetronic doing my nut in-2015-11-17-11.45.07.jpg   Aaarrgghh.... This starting/running XR3i MFi k-Jetronic doing my nut in-2015-11-17-11.46.08.jpg
Old Sep 2, 2020 | 03:10 PM
mumford2008's Avatar
mumford2008
Originally Posted by fordsteve77
Fault:
New plugs/HT leads
New coil
K&N air filter
did u get to the bottom of this? 5 years late I know I know!!
fordsteve77
Nov 17, 2015 10:51 PM
fordsteve77
Nov 17, 2015 07:21 AM
wallopadonkey
Ford XR Range
29
Nov 8, 2010 09:42 PM
juffer
Jun 8, 2007 09:29 PM
creedy
38
Dec 22, 2004 09:31 PM
