Distributors
Old Nov 16, 2015 | 04:58 PM
2Litre's Avatar
2Litre
Default Distributors
Hi all, a question about the distributor body on a three door, is it the same as 2wd/4wd as the replacement angled cap I bought does not seem to fit properly.
Thanks for any help.
T
Old Nov 16, 2015 | 05:16 PM
jamie's's Avatar
jamie's
The caps are a straight forward direct swap over,
So either should fit , so if its not fitting its possibly the wrong cap
If swapping from straight to angles or vise versa you need to swap the ht leads as wellto the matching type
Old Nov 16, 2015 | 05:24 PM
2Litre's Avatar
2Litre
Thanks for reply, no just replacing my original 3 door angled cap for another non original angled cap. looking at other cosworth distributors it looks like the cap sits inside the base. My original cap sit over the the distributors base.
This is why I ask if they differ?
Cheers.
T.
Old Nov 16, 2015 | 06:16 PM
jamie's's Avatar
jamie's
Mine sits inside the base
Old Nov 16, 2015 | 07:22 PM
2Litre's Avatar
2Litre
So the three door must be different then. Anyone know where I can get a cap that fits a 3 door.
Cheers.
T
Old Nov 16, 2015 | 09:28 PM
martysmartie's Avatar
martysmartie
They are the same, compare the two caps to see if theres a difference?
Martin
Old Nov 16, 2015 | 09:35 PM
gcfcos's Avatar
gcfcos
Cheers.
T
I get all my stuff from motorsport developments, always spot on and never had a problem
Old Nov 17, 2015 | 08:27 AM
Stu @ M Developments's Avatar
PassionFords Creator
They are all the same. The later ones have a steel shield around the outer making it "look" different, but fitment is identical.
All you need to do is hold the 2 caps together and check the lugs are in the same place.
cozzzzy power
Nov 18, 2015 08:41 PM
Pomstu1637
Nov 17, 2015 04:45 PM
LM-Cossy
Nov 16, 2015 09:00 AM
VEEDUBBED
Nov 15, 2015 05:39 PM
