1.3 fiesta to a 1.6 si conversion help ?
Hi all having a bit of a brain fart! I have a mk3.5 1.3 1995 which decided the other day to give up. I bought a 1.6 si 16v with the full engine loom and car loom. I put the engine in, I changed the trancever and key, plug the ecu in and the plug out of the ecu for the injection system. The lights, starter, altornator and fan section on the loom is all the same. Just questioning my self because I had to remove the edis module, will be ok with out this ? All main plugs line up and are in. Just wondering if there's something I'm missing? Photos of someone who has done this before would be a great help
