Evolution chips and spec of your cars
Nov 14, 2015 | 04:08 PM
Hi all just purchased a evolution chip from MSD for my s2 what sort of spec is other people running and power wise with one of these chips
Thanks
Nov 16, 2015 | 03:17 PM
Quote:
Originally Posted by
rs_jim
Thanks
or these chips not popular with these cars
Nov 21, 2015 | 01:50 PM
As you're MFI they don't really effect the final power that much, just remove boost cut and have a revised ignition map.
Power is primarily down to your turbo, IC, and ultimately what you can fuel for.
Nov 25, 2015 | 09:17 PM
I've got one fitted works fine with no issues at all.
Jan 1, 2016 | 09:37 AM
Is this difficult to install? Does it the same as the bayou chip?
Can it be used on every type of RST ECU?
Jan 2, 2016 | 08:08 AM
Jan 3, 2016 | 07:17 PM
I had mine fitted at a Ford RS specialist garage and then had it setup/ rolling road tuned.
Jan 8, 2016 | 11:40 AM
Easy to fit and work on all ERST ECU's.
cossie09
12
Dec 6, 2015 07:18 PM
rammer
Nov 15, 2015 07:38 AM
c20tbo
Nov 12, 2015 05:36 PM
YODI
Nov 10, 2015 06:31 PM
