Speedo sensor retaining pin
I've tried shit loads of WD, heat, breaking the sensor clip to free up more of the pin but my mole grips cant grip enough
Its stuck fast, any ideas?
I cant even snap it to be able to drill it
Yes a good set of mole grips that clamp hard. Get yourself a can of wurth rost off ice, give it a good squirt and then it should start moving! Done a couple of these and you won't get it out without gripping it properly.
