Towing a ford Smax on a trailer.
Old Nov 13, 2015 | 08:09 PM
Trist's Avatar
Trist
Default Towing a ford Smax on a trailer.
I am looking at buying a written off S Max and need to get it back to the Isle of Wight. I have a 3500 twin axel trailer and ford ranger pick up. I have taken the trailer licence as I passed after 1997. But will an s Max be to much fora trailer towed by a 2004 ranger??
Thanks.
Old Nov 14, 2015 | 08:51 AM
Carlos-Titx's Avatar
Carlos-Titx
Be best looking in the owners hand book mate. It will have it in there.
Old Nov 14, 2015 | 08:53 AM
As long as the ranger and the trailer weighs more than the Smax it should be ok. I can try and find out the weights of the cars if you want.
Old Nov 15, 2015 | 03:02 PM
bodace5's Avatar
bodace5
Aslong as the combined weight of the full rig doesn't weigh more then 3500kg you should be fine. If it did you'd need a class 3 licence and a tacho
Old Nov 15, 2015 | 03:32 PM
clairendave's Avatar
clairendave
Dave not Claire.
Ranger and smax will be similar weghts, even if its within legal weights it maybe better with something heavier than a ranger. Not sure why you'd need a tacho and class 3 If you have passed Your +E test.
Old Nov 15, 2015 | 03:44 PM
BigChuck's Avatar
BigChuck
Ford ranger 02-06
Weight and Capacities
Gross Train Weight5645
Gross Vehicle Weight2845
Max. Towing Weight - Braked2800
Max. Towing Weight - Unbraked750
From that as long as the smax and trailer is under 2800 kg you should be fine.
Old Nov 18, 2015 | 10:39 AM
bodace5's Avatar
bodace5
Passing your trailer test in a car just means you can tow over 750kg and up to 3500kg i believe, aslong as the vehicle is plated to tow up to 3500kg. And yes you wouldn't need a tacho if its not for hire or reward
Old Nov 18, 2015 | 03:34 PM
clairendave
Dave not Claire.
B+E is not restricted to 3500kg.
Even on a B only you can tow over 750kg, BUT the PLATED max weights (not actual) of the vehicle and trailer can only add upto 3500kg.
Old Nov 18, 2015 | 06:30 PM
bodace5's Avatar
bodace5
Category B+E
You can drive a vehicle with a*MAM*of 3,500kg with a trailer.
The size of the trailer depends on when you passed your test. If you passed your test:
before 19 January 2013 you can tow any size traileron or after 19 January 2013 you can tow a trailer with a*MAM*of up to 3,500kg
Copied from the government website.
Old Nov 18, 2015 | 09:02 PM
clairendave
Dave not Claire.
Category B+E
So if you passed your test after 19th Jan 2013 your limited to a 3500kg trailer behind a suitable 3500kg vehicle.
Before that date your trailer can be heavier. (which is unlikely anyway)
Its been debated thousands of times on various forums, it has also been proven that the direct.gov website is misleading.
Old Nov 18, 2015 | 09:14 PM
clairendave
Dave not Claire.
Sorry i misread your post. I read it that your limited to 3500 overall.
bigryrs
Nov 21, 2015 07:15 PM
josenovo
Nov 17, 2015 01:08 PM
mulla
22
Nov 17, 2015 08:25 AM
Topjoe9
Nov 14, 2015 10:04 AM
AlexisFuentes
Ford Fiesta
Nov 13, 2015 09:25 AM
