Help transit connect
hi have transit connect tdci that is not feeding fuel to the common rail an instead is just sending it back to the tank, changed the pump an its still do same thing an also changed the 3x fuel sensors an still no go, anyone help me out as a stuck for van for work
Have you got rid of all the air out of the system. These engines can be a nightmare to start. Have you changed the fuel filter as well. What i do at work is i use a car petrol fuel pump and put it on the fuel filter and the pipe to the engine and use that to suck the diesel through.
