Cosworth oil pickup pipes
Old Nov 13, 2015 | 12:33 PM
Ridgey's Avatar
Ridgey
Default Cosworth oil pickup pipes
Is there a difference in them between the 2wd and 4wd?
Reason i ask is that my 2wd sump looks to have a circular mark in the bottom of it from the pickup pipe. (sorry no pic a present).
So my pickup must be VERY VERY close to the base of the sump, to the point where i would have thought it would restrict flow and potentially sunction to the bottom.
Do 4wd pickups go deeper? Thinking i may have the incorrect one..
thanks
Old Nov 13, 2015 | 01:51 PM
James Porter's Avatar
James Porter
Yes mate 4x4 ones sit very close to the inside of a 2wd sump
Old Nov 13, 2015 | 02:16 PM
Ridgey's Avatar
Ridgey
Bugger, will look into that then, i think i have another one somewhere.
Old Nov 13, 2015 | 03:34 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
Can you fit them wrong as well? Mate of mine did his sump gasket and some how ended up with the pick up pipe to close to the sump oil starved it and ended up needing a new crank shaft
Old Nov 13, 2015 | 05:03 PM
Nash's Avatar
Nash
Cake lover!
Dave you can use a 4x4 pick up on a 2wd sump but they need be bending slightly to stop the issue you have mentioned. Loader had the same issue and it trashed the big ends, this could well be what's happened to yours mate.
Old Nov 13, 2015 | 07:33 PM
Ridgey's Avatar
Ridgey
Yeah it could have contributed.
Just dug out my original std pump and pickup, and the pickup is a few mm higher.
I'll put this pickup back on.
Always a learning curve cossie ownership
Old Nov 13, 2015 | 07:57 PM
Nightmare so it could of been this pipe which had caused the damge to the engine.
Old Nov 13, 2015 | 08:24 PM
Tim Wharton's Avatar
Tim Wharton
When I wanted to fit a 4x4 pump and pick up pipe to my 2wd sumped engine I made a sort of jig to check the positioning of the pick up pipes to compare 2wd with 4x4 and apart from a slight mod to the JG baffle to all seamed to line up ok
neilscott83
Nov 13, 2015 08:55 AM
nick46
Nov 12, 2015 05:07 PM
RB26DETT
Nov 10, 2015 09:14 PM
mikej857
Nov 9, 2015 08:54 PM
